  • Bergland, powered by IWC.
  • forum 13 replies
  • last reply by Mr. Bob Bunnik 10 Mar 2019
    HEBE
    Master 1867 posts
    28 Feb 2019, 6:45 p.m. 28 Feb 2019, 6:45 p.m.
    Just out of the safe for some fresh photos, after many years into the bank
    safe.
    It is a strange watch, with a very rare IWC movement, the cal. 983.
    The diameter is 53 mm, similar IWC cases have 49 mm in diameter.
    But this one has a 14 carat gold case, not 18 carat gold as similar IWC
    models.
    Some years ago, I was thinking about selling it, but I will keep it in
    collection, because it is a 92 gramm beauty and I like that Fibonacci design
    very much.
    Master 3202 posts
    28 Feb 2019, 7:02 p.m. 28 Feb 2019, 7:02 p.m.
    Wow Heiko
    What a stunning watch, I'm glad you kept it. What year is it from?
    HEBE likes this.
    Moderator 3583 posts
    28 Feb 2019, 8:16 p.m. 28 Feb 2019, 8:16 p.m.
    here is mine in silver.
    HEBE likes this.
    HEBE
    Master 1867 posts
    1 Mar 2019, 10:36 a.m. 1 Mar 2019, 10:36 a.m.
    Wow Heiko
    Best Regards
    Mark
    Thanks Mark.
    Year of produktion: I have got some details from Mr. Klaus on the caliber 983
    some years ago, but cant find it currently, sorry.
    So, just from my mind, late 70s - early 80s ?!
    Well, tasts are changing during the years and the taste for this watch has
    rised. From todays view no thoughts about selling this rarety anymore.
    Heiko
    Regnimelf3717 likes this.
    HEBE
    Master 1867 posts
    1 Mar 2019, 10:45 a.m. 1 Mar 2019, 10:45 a.m.
    @Tonny
    Thanks for shwowing the silver variant, Tonny.
    Just a hint, the cal. mounting screws are missing.
    That could occure a fracture of the winding screw ?!
    Heiko
    1 Mar 2019, 11:29 a.m. 1 Mar 2019, 11:29 a.m.
    Thx, will look into it. Hadn't really noticed it.
    1 Mar 2019, 12:46 p.m. 1 Mar 2019, 12:46 p.m.
    Beautiful gold and silver PW's, gentlemen! Thanks for sharing them with us!
    HEBE and Regnimelf3717 like this.
    favorite 2
    Nelson Herring
    Master 2723 posts
    2 Mar 2019, 3:57 p.m. 2 Mar 2019, 3:57 p.m.
    Heiko,
    Your posts always make me wonder just what other surprises you have stashed
    away in your bank!
    This is a beauty- thank you for sharing it with us.
    Nelson
    favorite 2
    HEBE
    Master 1867 posts
    3 Mar 2019, 10:20 a.m. 3 Mar 2019, 10:20 a.m.
    Thanks to all for participating this BERGLAND thread.
    The difference between the cal. 9x2 and cal. 9x3 is limited to the balance,
    cal. 9x2 with screw balance, cal. 9x3 balance without screws the
    simplification of the regulation system and no Breguet spiral.
    If anyone can estimate what was actually saved by this change, please let me
    know, because I have absolutely no idea about it ?!
    WhippetWonder
    Graduate 141 posts
    8 Mar 2019, 6:20 a.m. 8 Mar 2019, 6:20 a.m.
    Very nice!
    ADRIAN van der Meijden
    Master 2662 posts
    8 Mar 2019, 1:20 p.m. 8 Mar 2019, 1:20 p.m.
    Hi Heiko,
    About the differences between balance and balance spring.
    It is difficult to determine the difference in terms of money : no idea.
    In terms of accuracy : a balance with balance screws (often gold) can be
    regulated more accurate than a flat balance wheel.
    The material and helical structure of a Breguet balance spring are more
    accurate and less sensitive for temperature changes than the 'normal' balance
    spring.
    So, generally speaking, the original IWC should be more precise than the
    modified Bergland movement. But how much is that effect?. I am sure that there
    are examples of the Bergland which are more accurate than some original
    movements.
    I am also sure that you know all about what I am writing(=:
    Adrian,
    (alwaysiwc).
    HEBE
    Master 1867 posts
    8 Mar 2019, 4:46 p.m. 8 Mar 2019, 4:46 p.m.
    Thanks Adrian,
    I have just got some details about this topic from Richard Habring , which
    may also be interesting for you.
    I would estimate that this was ultimately a good CHF 150/200 saving on the
    factory 's production costs.
    The KIF is a standardized regulating system that was (and will be) made with
    existing tools.
    At that time it cost just a few francs apiece.
    The adjustment to the respective caliber is made only by the bridge-side shock
    protection, the adjustment for the respective spiral size (which in turn
    depends on the size of the balance) is made through the hole for the spiral
    stud and its distance to the center.
    Consider that at that time all of our own calibres were equipped with
    Breguet hairspring. Had you wanted to make the conversion internally would
    have been your own punching tool for a R ucker for the flat spiral due, wire
    erosion or laser cutting was then not yet. The tooling costs have been saved
    simply by assembling the Spirofin.
    The biggest savings came from the flat spiral, which was simply installed
    and straightened, while the Breguet spiral had to be "laid out" a bit more
    complex.
    Heiko
    Michael_Chen_001 likes this.
    Master 2662 posts
    8 Mar 2019, 8:50 p.m. 8 Mar 2019, 8:50 p.m.
    Heiko, a more perfect answer from a world known expert as Richard Habring is
    not possible.
    Adrian,
    (alwaysiwc)
    10 Mar 2019, 8:38 a.m. 10 Mar 2019, 8:38 a.m.
    Beautiful watch Heiko, great you kept it!
