  • Big Pilot and Vertical Clutch
  • forum 3 replies
  • last reply by MarkFleminger 13 Mar 2020
    Jack Straw
    Graduate 53 posts
    13 Mar 2020, 12:05 p.m. 13 Mar 2020, 12:05 p.m.
    Hi, does anyone know if the big pilot, specifically the 5002, has a vertical
    clutch coupling? I ask because my local AD mentioned this as a reason
    servicing would be expensive, but from researching this it looks like vertical
    clutch is mostly associated with chronographs.
    Any help is appreciated.
    Regnimelf3717 likes this.
    Master 3212 posts
    13 Mar 2020, 4:42 p.m. 13 Mar 2020, 4:42 p.m.
    Vertical Clutch will only be found in a chronograph movement.
    This AD obviously doesn't know the difference between a chronograph and
    chronometer!!!!
    Jack Straw
    Graduate 53 posts
    13 Mar 2020, 5:17 p.m. 13 Mar 2020, 5:17 p.m.
    The person also referenced the double barrel which to my knowledge the 5002 is
    a single barrel.
    Master 3212 posts
    13 Mar 2020, 5:55 p.m. 13 Mar 2020, 5:55 p.m.
    Correct.
    Last Big Pilot Reference 5009 had single barrel and Cal 51111
    Big Pilot Ref 501001 received Double Barrel and Cal 52110 movement
