I just purchased a IWA66284 Ingenieur bracelet for my Chrono Racer, is there instructions on how to remove the push pins and strap and install the bracelet?
Thank you.
Thank you.
You will find the instructions here, starting on page 27:
Instruction Manual Ref. 3785
Good luck!
There is a little button on the strap near the lugs, does that have to be pressed in to release the push pin? The instructions don't say.
You have to keep this pin pressed and slide out the bar that links the strap or bracelet to the case to separate them.
This is the pin on a bracelet, on a strap it is located identically:
Okay I see, thank you for responding.
I am looking at a 3785 Chronograph Racer and am interested in purchasing a bracelet. If you don't mind...could you tell me which AD you purchased from and for what price?
I don't have an AD nearby. I already contacted Torneau which is 5 hours away and they were not at all helpful.
Thanks,
Matt
