Caliber 89: douby on power reserve
As a watchmaker I must first say that it's not possible to diagnose precisely the problem you've described without examining the timepiece inside at the bench.
Having said that, one or more reasons can be the problem though not in any particular order.
- movement once had a "shorter generic" mainspring replaced
- movement is gummed up due to no service in many years
- crown is clogged making it difficult to wind up the watch in full
There could be other reasons as well so, in my opinion, your watch will need to be totally disassembled by a professional watchmaker and have all the parts checked for wear and whether they are original. This procedure is normally done as part of a complete overhaul.
To conclude, I strongly recommend that you have your IWC Mark 11 timepiece serviced by none other than the IWC factory in Schaffhausen. Your local AD or official service center can arrange that for you.
Jack Freedman
