Awaiting delivery of this fine doppel chrono. rubbing hand with glee
Ive tried looking up the service portal and the diagrams for both watches, but i cant find the answer. Would anyone happen to know anything about the anti-magnetic protection for the DFB watch.
The DFB watch is based on the Spitfire Double Chrono (ref 3718 02).
The Spitfire has antimagnetic soft iron core protection
From the IWC technical documents the Spitfire dial is soft iron (silver plated) in nature and this gives the watch protection in the front. The spitfire also has a full soft iron core surrounding the movement and back of case.
Does the DFB have the same iron core antimagnetic protection?
Or has this been removed from the watch as it is predominantly a "Football sports watch"?
The dial on the DFB is different from the Spitfire double chrono also, does this mean that the dial side of the antimagnetic protection is lacking on dial side the DFB double chrono?
would be most grateful if someone chould shed some light before i go near the MRI room.
best regards from Singapore,
JM
