  • Identification Schaffhausen
  • forum 11 replies
  • last reply by Pbaeta 28 Nov 2018
    Pbaeta
    Apprentice 7 posts
    28 Nov 2018, 10:06 a.m. 28 Nov 2018, 10:06 a.m.
    Hello good morning everyone,
    I would like to ask for some assistance in identifying my IWC, as after
    several hours of searching online yielded nothing that matches this particular
    timepiece. It is fully functional and I suspect it has the original strap, but
    as I do not have appropriate tools, I do not want to open the case myself to
    find any markings within.
    EDIT: I believe this to be a 1921 Caliber 74, but I've not been able to find
    one with this exact match of case, dials and face
    Any help would be greatly appreciated.
    Thank you in advance
    28 Nov 2018, 1:57 p.m. 28 Nov 2018, 1:57 p.m.
    Your watch is probably a Cal 83, but without seeing the movement I cannot tell
    you more.
    Cal 83 was in production from 1930 to 1947. The Breguet hands are unusual.
    Pbaeta
    Apprentice 7 posts
    28 Nov 2018, 2:05 p.m. 28 Nov 2018, 2:05 p.m.
    Hey Mark, thank you, much appreciated. I will try to get a few more pictures
    to see if we can dig a bit deeper. I tried checking the 83s but I cannot find
    any with the embossed numerals or with this specific format of numerals
    either. I suppose I might not be looking in the right places.
    I will come back with more pictures once I have them, in the meantime, thank
    you for your help
    Pbaeta
    Apprentice 7 posts
    28 Nov 2018, 5:25 p.m. 28 Nov 2018, 5:25 p.m.
    Hello again, I was able to get it open and take a few more pictures. Here they
    are:
    28 Nov 2018, 6:14 p.m. 28 Nov 2018, 6:14 p.m.
    Great to see the pictures. Confirming that the movement is a Cal 83.
    The serial number in the caseback dates the watch to between 1935 to 1937.
    If you give me the serial number on the movement, we can firm this up.
    Pbaeta likes this.
    Pbaeta
    Apprentice 7 posts
    28 Nov 2018, 6:16 p.m. 28 Nov 2018, 6:16 p.m.
    I believe it is 44296 if i am reading it correctly
    EDIT: or it is 56277, it is quite hard to tell with the numbering
    28 Nov 2018, 6:30 p.m. 28 Nov 2018, 6:30 p.m.
    Those are not correct.
    It needs to be a 6 digit number. You will need a magnifying glass.
    Pbaeta
    Apprentice 7 posts
    28 Nov 2018, 6:34 p.m. 28 Nov 2018, 6:34 p.m.
    Took a bit more than a magnifying glass, had to get my son to read it :D
    It is 962779
    28 Nov 2018, 7:02 p.m. 28 Nov 2018, 7:02 p.m.
    The watch was made and cased in 1937.
    Unfortunately there is no reference number stamped into the caseback. During
    this time, it was not common to do so.
    Pbaeta likes this.
    Pbaeta
    Apprentice 7 posts
    28 Nov 2018, 7:08 p.m. 28 Nov 2018, 7:08 p.m.
    Thank you very much Mark, that already helps quite a lot. There is a number
    stamped in the inside of the caseback, I'm not sure that makes a difference?
    The number is 998129
    28 Nov 2018, 7:30 p.m. 28 Nov 2018, 7:30 p.m.
    That is the case number and I used it to date the case.
    Pbaeta
    Apprentice 7 posts
    28 Nov 2018, 7:32 p.m. 28 Nov 2018, 7:32 p.m.
    Well, makes sense. Thank you very much for your help on this one Mark, you're
    a star.
    Have a great evening :)
    Regnimelf3717 likes this.
