  • IWC buckle, thicker tang than usual?!
  • last reply by ace 18 Apr 2018
    Mr. Koki Akala
    16 Apr 2018, 10:14 p.m. 16 Apr 2018, 10:14 p.m.
    Hey guys,
    I picked up this IWC tang buckle that came off of a 3270-04 LPP. I received it and was surprised because it doesn't fit the Santoni strap I have, because the tang is too thick. The LPP came out in 2016, did IWC change the tang twice since then?! ie. Once to the thinner tang but "IWC" still off-centred, and then to the newer buckles with the centred "IWC"? I don't have any reason to believe it isn't authentic, but it is weird to me.
    Thanks!
    /site_media/ckeditor_images/e2862befe1a57737ea90510c6b0a9288.jpg
    Master 1982 posts
    16 Apr 2018, 10:49 p.m. 16 Apr 2018, 10:49 p.m.
    It appears that the seller misidentified that tang buckle - if it were from a 327004 it would have come on a Santoni strap as well. I am guessing this one came off of an Aquatimer pre-2009. The buckle you need should look like this:
    /site_media/ckeditor_images/c38d33c9a340754dec7a259ce2cb46a8.jpg
    Mr. Koki Akala
    17 Apr 2018, 12:48 p.m. 17 Apr 2018, 12:48 p.m.
    Ben has written:
    Thanks a lot Ben, that makes a ton of sense! I contacted seller and have received a partial refund due to the error. Very helpful.
    17 Apr 2018, 5:18 p.m. 17 Apr 2018, 5:18 p.m.
    How about the stitching at the tip of the strap? It doesn't look right to me, as if a not too experienced strap maker went wrong. Is this normal? I wouldn't like my expensive strap to look that way.
    18 Apr 2018, 4:19 p.m. 18 Apr 2018, 4:19 p.m.
    One more view of the correct  "Pin " width of the tang buckle you need. Some AD's stock both/site_media/ckeditor_images/8651d6a23ad21d9f13313b827be004c4.jpgold and new IWC version buckles. Not sure about the Boutiques.
