  • Portoguese 3714 Straps
  • forum 9 replies
  • last reply by Tonnymoderator 14 Nov 2016
    Mr. jJAMES WALKER
    Apprentice 7 posts
    12 Nov 2016, 6:52 p.m. 12 Nov 2016, 6:52 p.m.
    Does anyone know the article or item code on the back of any original IWC 20MM - 18mm Deployant of Pin straps?
    I currently have a Porto 3714 and a Pilot 377709
    Thank you all in advance.
    JC
    Moderator 3583 posts
    12 Nov 2016, 8:03 p.m. 12 Nov 2016, 8:03 p.m.
    Hello, I am sorry I had to edit your post since we don't allow links to commercial sites.
    I took a look at the straps and they look all OK to me.
    The ref for the folding clasp is IWA05337.
    Tonny, moderator.
    Mr. jJAMES WALKER
    Apprentice 7 posts
    12 Nov 2016, 11:57 p.m. 12 Nov 2016, 11:57 p.m.
    Tonny Berteloot has written:
    Tonny, moderator.
    Tonny thank you. So both of those straps are oem straps, that are 20mm and will work and suit my Porto 3714 chrono?
    Mr. jJAMES WALKER
    Apprentice 7 posts
    13 Nov 2016, 12:02 a.m. 13 Nov 2016, 12:02 a.m.
    Another question please. That reference you provided was for the deployant, not the straps, correct? Do the straps have codes?
    13 Nov 2016, 11:18 a.m. 13 Nov 2016, 11:18 a.m.
    Hello , indeed the ref was for the folding clasp.
    Here are some references for the straps for folding clasp :
    IWA20075 black alligator
    IWA20071 dark brown alligator
    IWA 56154 blue alligator
    Mr. jJAMES WALKER
    Apprentice 7 posts
    13 Nov 2016, 5:15 p.m. 13 Nov 2016, 5:15 p.m.
    Perfect and thank you Tonny. I appreciate the confidence your knowledge gives me.
    Best
    JC
    Mr. jJAMES WALKER
    Apprentice 7 posts
    13 Nov 2016, 5:51 p.m. 13 Nov 2016, 5:51 p.m.
    The serial number written into the strap is not the reference of the strap !
    Ref of the strap is : IWA20071
    Written into the strap : BVAI A21700
    Does this make sense Tonny that the Reference and the strap serial would be different?
    Do u know the Reference A----- of the burgundy strap?
    I searched the web for all these questions but could not find them. So once again, thanks for your time on this matter.
    Mr. jJAMES WALKER
    Apprentice 7 posts
    13 Nov 2016, 8:31 p.m. 13 Nov 2016, 8:31 p.m.
    www.weeber.biz/IWC/Workbook/2006/3714.pdf
    For you Tonny I finally found it, this is the Workbook references for all information in regards to the Porto 3714 Collection.
    Please for future inquiries.
    As you can see the Strap references are the IWC original straps choices.
    The references you graciously provide will indeed fit, but are not sourced to the Porto 3714,
    Best
    Jim
    13 Nov 2016, 8:52 p.m. 13 Nov 2016, 8:52 p.m.
    Hello Jim, the workbook you use is from 2006. My source is the workbook 2016.
    And the references I gave are these that go with the 3714.
    The burgundy strap was not in the 2006 workbook. I will look for it tomorrow.
    14 Nov 2016, 6:52 a.m. 14 Nov 2016, 6:52 a.m.
    The burgundy strap is not in the workbook 2016 named as burgundy, there is a strap "alligator dark red" that must be the one you asking for.
    This strap only is on order in the XS size ( standard -10mm ) and has the ref. IWA61851.
