  • Portuguese updated movement
  • last reply by JonasBP 16 Jun 2008
    Jonas Bro Pedersen
    Apprentice 4 posts
    15 Jun 2008, 7:45 a.m. 15 Jun 2008, 7:45 a.m.
    I have a question regarding the 7 day movement in the Portuguese Automatic 500107.
    The Port has the calibre 51011, whereas the Big Pilot has the calibre: 51111. I thought these two watches basically had the same movement. I'm aware, that the movement in the BP recently got updated, so I was wondering if the same thing might happen to the Portuguese.
    Jonas
    15 Jun 2008, 7:20 a.m. 15 Jun 2008, 7:20 a.m.
    Some answers....
    Jonas - The Portuguese was originally based on the Cal. 50010 which had an oscillating balance with a 2.5 Hz frequency. It was UPDATED to the 51011 that you specified. The Big Pilot went through the same movement update - hence you may see some talk about "transitional Big Pilots". The chart above has a "forerunner" column that indicates what prior movement caliber the current movement was derived.
    Notwithstanding, there certainly has been a tremendous amount of build-up and advancement of the Cal. 5000 family of movements. See the link below, and search the archives for more complete research - it can keep you busy for a few hours. All your answers are here someplace...
    Discussion on Cal 5000 Movements
    www.iwcforum.com/Movements/Calibre5xxxxChart.jpg
    Master 1982 posts
    15 Jun 2008, 6 p.m. 15 Jun 2008, 6 p.m.
    I believe the main difference between the Portuguese and BP updated movements is that the portuguese has a seconds sub-dial at 9:00, whereas the BP has a central seconds hand. The Portuguese movement is also a little prettier as it is made to be visible through the case back.
    16 Jun 2008, 1:25 a.m. 16 Jun 2008, 1:25 a.m.
    Appreciated Richard
    Jonas Bro Pedersen
    Apprentice 4 posts
    16 Jun 2008, 7:30 a.m. 16 Jun 2008, 7:30 a.m.
    Thank you for the very informative and helpful answers.
    Jonas
