  • Ref. 3711 - crown distance to case
  • forum 10 replies
  • last reply by Ben 13 Feb 2019
    Mr. JW
    Apprentice 4 posts
    26 Nov 2018, 10:26 a.m. 26 Nov 2018, 10:26 a.m.
    One and all - as this is my first post here, let me start by expressing my
    appreciation for the knowledge shared here.
    I have two IWC's at this time, a wonderful and classic Ref. 5002 Big Pilot and
    a recently acquired Ref 3711 Doppelchronograph. I have a question regarding
    the latter. I find the screw-in crown action to be somewhat strained. It does
    not push in and close easily and when in closed position there seems to be
    quite a distance between the crown and the case. This is the new 'Probus'
    crown - a service replacement (done by IWC). Can anyone comment on whether
    this is normal or whether I should have a watchmaker look at this... I will
    upload two pics, the first mine and the second one from the seller where I
    bought the watch.
    You can see the gap between crown and case on both pictures. (Note: the seller
    has an excellent reputation, this post is in no way about the seller btw).
    Thanks in advance
    Jw
    26 Nov 2018, 4:25 p.m. 26 Nov 2018, 4:25 p.m.
    Here are two photos of my 3711. You can see there is very little gap between
    the crown and case. My Doppel has the origianl fish crown. Note too the
    disctinve and unique domed crystal of the 3711. If yours is a probus crown it
    was changed at some point, probably during a service.
    Mr. JW
    Apprentice 4 posts
    26 Nov 2018, 4:36 p.m. 26 Nov 2018, 4:36 p.m.
    Thanks Bill. The crown was indeed replaced during an IWC Service. Does your
    crown easily push back and screw-in and could you indicate if you have half a
    turn to close or less. Mine needs only a small nudge (perhaps .1 of a turn).
    And I do have the domed crystal - this gives this watch that classic/vintage
    look in my opinion, which is why I went for a 3711.
    26 Nov 2018, 7:07 p.m. 26 Nov 2018, 7:07 p.m.
    The crown needs a bit of a push as you turn it minimally anti-clockwise to
    engage and then screw in. It works easily for me.
    Slashd0t
    Connoisseur 355 posts
    27 Nov 2018, 6:26 a.m. 27 Nov 2018, 6:26 a.m.
    Doesn't like right IMO - likely stripped and needs a look at - I would send it
    in for a service.
    A320Driver
    5 Jan 2019, 12:53 p.m. 5 Jan 2019, 12:53 p.m.
    Stumbled over this threat. Did you keep the watch? I found one that uses the
    same picture you provided from the seller. Did you find out what was wrong
    with the watch?
    Mr. JW
    Apprentice 4 posts
    5 Jan 2019, 1:05 p.m. 5 Jan 2019, 1:05 p.m.
    I kept it and sent it over to IWC via my local AD last week.
    A320Driver
    5 Jan 2019, 1:11 p.m. 5 Jan 2019, 1:11 p.m.
    Thanks for your quick update. Strange that the watch still seems to be listed.
    I contacted the seller to get some information. Really nice watch by the way.
    Mr. JW
    Apprentice 4 posts
    13 Feb 2019, 10:36 a.m. 13 Feb 2019, 10:36 a.m.
    Today I receided my watch back from IWC and I thought I'd close off this
    thread and provide information so others can benefit from this experience. I
    had a comprehensive service performed on the watch, in addition to the request
    to resolve the issue with the crown. This entailed things like a complete
    movement dismantling and ultrasonic clean of all movement parts for example.
    I found out that you could request IWC to replace the 'Probus' crown with the
    'Fish' crown ! This I did, bringing the 3711 back to its original
    configuration which is nice.
    Watchlovers View likes this.
    13 Feb 2019, 1:55 p.m. 13 Feb 2019, 1:55 p.m.
    What a fantastic outcome.
    Thank You for the update.
    Master 1982 posts
    13 Feb 2019, 8:29 p.m. 13 Feb 2019, 8:29 p.m.
    Wow - amazing to see that IWC is now offering the "fish crown" for older
    pieces other than the 5002. Very nice!
