  • Rubber on lunette of Aquatimer
  • forum 5 replies
  • last reply by Clem Ho 3 Jun 2019
    Trickydicky
    1 Jun 2019, 5:54 a.m. 1 Jun 2019, 5:54 a.m.
    Good morning.
    I have now added an Aquatimer IW376705 Stainless steel coated rubber black to
    my collection.
    I small area on the lunette the rubber has been damaged.
    Is it possible to just have the rubber in this area replaced ? or is this
    going to be a big ( and expensive) job ?
    Master 1982 posts
    2 Jun 2019, 5:50 p.m. 2 Jun 2019, 5:50 p.m.
    I believe Clem Ho recently had similar work done on one of these - hopefully
    he will be able to chime in.
    ClemHo likes this.
    Clem
    Insider 398 posts
    3 Jun 2019, 6:57 p.m. 3 Jun 2019, 6:57 p.m.
    I do not believe the rubber is repairable. Pardon my ignorance but I'm not
    sure which part (the lunette) you are referring to.
    I recently had a small tear on the bezel of mine. IWC replaced the entire
    bezel..
    Master 1982 posts
    3 Jun 2019, 7:07 p.m. 3 Jun 2019, 7:07 p.m.
    Sorry Clem, I mistakenly understood that the rubber was repaired on your watch
    - I didn't realize the whole bezel was replaced. Well that makes sense - I had
    previously heard that the rubber coating was not something that could not be
    "patched."
    ClemHo likes this.
    Trickydicky
    3 Jun 2019, 8:19 p.m. 3 Jun 2019, 8:19 p.m.
    Good evening and thanks for the reply. Yes, you are correct, it is the rubber
    on the bezel that I am refering to. May I ask how much IWC wanted for the
    repair ? The damage on mine is very slight and if it is reasonable I may have
    it done. If not I will wait.
    Richard
    Clem
    Insider 398 posts
    3 Jun 2019, 10:19 p.m. 3 Jun 2019, 10:19 p.m.
    IWC may recommend a complete service if one hasn't been done in recent years.
    If yours doesn't need it I would suggest holding off until it does assuming
    the damage to the rubber isn't too bad.
    I would suggest calling or going into the boutique (or your AD) for a quote.
