  • Setting my moonphase
  • forum 5 replies
  • last reply by neh1 3 Feb 2009
    niels erland heidoe
    Connoisseur 131 posts
    2 Feb 2009, 8:10 p.m. 2 Feb 2009, 8:10 p.m.
    Hi all,
    I found the below (in quotation marks) on TZ, written by Foie Gras and MF. I hope I don't violate any copyrights. The description of how to set the moonphase came with a general description of the original ref. 5251 Portofino.
    My question is, can I set the moonphase of my VC Portofino in a similar manner?? Or, do I need to go a full 24 hour cycle to advance the moonphase?
    "There are only 2 positions on the crown; pushed in is for winding and pulled out for time and moon phase settings. The moon phase is easily set, by cycling between 10 p.m. forward to 2 a.m., and then back again, each cycle advancing the phase of the moon by one day."
    Greg Steer
    Master 2688 posts
    3 Feb 2009, 10:30 a.m. 3 Feb 2009, 10:30 a.m.
    The following is from the instruction booket for the Ref. 5448 Portofino (I've provided a link to the PDF file on the link below):
    "Setting the moon phase display
    The moon phase display is connected to the hour hand and can be adjusted by moving the hands forwards (crown in position 2). "
    That would seem to indicate you need to advance the hour hand a full 24 hours.
    Cheers from the cellar
    PORTOFINO HAND-WOUND Reference 5448
    Greg Steer
    Master 2688 posts
    3 Feb 2009, 6:05 a.m. 3 Feb 2009, 6:05 a.m.
    Limk correction
    Greg Steer
    Master 2688 posts
    3 Feb 2009, 4:40 a.m. 3 Feb 2009, 4:40 a.m.
    Try this link
    www.iwc.ch/upload/instructions/IWA33777_REF5448.pdf
    Which does work
    IWC software adds "https://www.iwc.com/member/forum/" to the begining if I put it in the link URL to read:
    https://www.iwc.com/member/forum/www.iwc.ch/upload/instructions/IWA33777_REF5448.pdf
    Which does not work.
    niels erland heidoe
    3 Feb 2009, 8:25 p.m. 3 Feb 2009, 8:25 p.m.
    Thanksnt
    niels erland heidoe
    3 Feb 2009, 1:20 p.m. 3 Feb 2009, 1:20 p.m.
    Diff btwn old and new Portofino...
    ... in terms of this particular feature?
    I have searched around, but so far found no reason why it should NOT be possible to set the moonphase on the new c. 98 the same way as for the c. 95.
    Anyone?
    It's quite a job to set the moon phase, and more importantly, I have a strong feeling that it's not that great winding the mvmnt. that excessively.
    Please help out, before I go nuts, I can't get this out of my head now!! :)
