  • To lubricate or not to lubricate?
  • forum 12 replies
  • last reply by xiaonvren 20 Dec 2014
    Mr. Thomas Vigetorp
    Connoisseur 148 posts
    29 Jun 2014, 5:56 p.m. 29 Jun 2014, 5:56 p.m.
    The bracelet on my 3239 occasionally makes a screeching noise. It's not a big problem but I'm considering applying some lubricating oil on it. Would that be a good idea or a bad idea?
    Thomas
    29 Jun 2014, 6:03 p.m. 29 Jun 2014, 6:03 p.m.
    Bad, unless you don't wear long sleeve shirts nor mind a well lubricated wrist!
    29 Jun 2014, 6:56 p.m. 29 Jun 2014, 6:56 p.m.
    Try some graphite from a pencil.
    29 Jun 2014, 8:32 p.m. 29 Jun 2014, 8:32 p.m.
    My Mission Earth Strap does the same thing.
    Werner Rosier
    Connoisseur 301 posts
    29 Jun 2014, 10:44 p.m. 29 Jun 2014, 10:44 p.m.
    Rave has written:
    ...and then you will be obliged to wear black shirts for a few months :-)
    Master 6726 posts
    30 Jun 2014, 12:15 a.m. 30 Jun 2014, 12:15 a.m.
    There may some grit and dirt embedded in the links. I use a bit of non abrasive toothpaste and a toothbrush to clean it under running water.
    That often dislodges the offending dirt.
    Master 3212 posts
    30 Jun 2014, 3:41 a.m. 30 Jun 2014, 3:41 a.m.
    Bill B. has written:
    Hi Bill,
    Toothpaste is very abrasive and can leave deposits in the links causing unnecessary wear. I would recommend a toothbrush, liquid hand soap (which is gentle) and running water to clean up the links of a bracelet.
    Master 6726 posts
    30 Jun 2014, 11:55 a.m. 30 Jun 2014, 11:55 a.m.
    @Mark, I agree. That's why I said non abrasive toothpaste. Hand soap will work as well.
    Mr. kenneth laycock
    Connoisseur 271 posts
    1 Jul 2014, 4:16 a.m. 1 Jul 2014, 4:16 a.m.
    Liquid soap is PH neutral so it's the perfect cleaner for bracelets and the watch case-I've cleaned my watches this way for a long time now,without any issues.A soft toothbrush as others have mentioned is perfect for the job. Finish by using soft tissues to absorb the excess water,before a final clean with a soft micro fibre cloth that you would use for cleaning the lenses on spectacles.
    Kenneth.
    Mr. Thomas Vigetorp
    28 Oct 2014, 2:56 p.m. 28 Oct 2014, 2:56 p.m.
    Just a brief update in case someone else is experiencing a similar problem.
    Cleaning the bracelet provided some temporary relief but the noise kept coming back and getting worse. I eventually located the problem to be where the bracelet attaches to the case at the 12 o'clock position. I took the watch to my AD as I thought maybe there was some uneveness that needed a touch of polishing. Their watchmaker applied some lubrication where the bracelet attaches to the case and it has been noise free since.
    Thomas
    Mr. Don Kim
    Graduate 17 posts
    28 Oct 2014, 3:09 p.m. 28 Oct 2014, 3:09 p.m.
    Thank you for the tip. I have exactly same problem with a noise in the bracelet. I had better take it to the AD.
    Mr. Robert Dr. Timár
    Connoisseur 518 posts
    29 Oct 2014, 5:08 a.m. 29 Oct 2014, 5:08 a.m.
    I use liquid soap and soft tooth-brush too, but never needed the micro-fibre cloth at the end.
    On some rare occasions at the watchmaker he can do an ultrasound bath for the bracelet and that does the job too. And/or to take the bracelet pieces apart and clean them one by one.
    Mr. XIAO NVREN
    Apprentice 3 posts
    20 Dec 2014, 11:09 a.m. 20 Dec 2014, 11:09 a.m.
    Nice excercise ! and to balance the awsome selection listed above down a bit, i would be very happy with an aquatimer vintage, and the beautiful Portuguese PC in steel.
    my site:buy fifa coins
