  • Battery for 3727
Battery for 3727
  • forum 3 replies
  • last reply by Tonnymoderator 28 May 2017
    Mr. Ide fix
    Apprentice 11 posts
    27 May 2017, 12:29 p.m. 27 May 2017, 12:29 p.m.
    I would like to change my battery for my 3727 wit MecaQuartz movement, which is the factory battery that goes in it? Thanks
    Moderator 3666 posts
    27 May 2017, 3:07 p.m. 27 May 2017, 3:07 p.m.
    Hello, I believe the battery is a standard one. If you open the case, you will see the brand used and a number. The number is for the size of the battery and is usefull is you can't find the same brand. With that number, you can buy the right size from another brand.
    Mr. Ide fix
    Apprentice 11 posts
    27 May 2017, 5:37 p.m. 27 May 2017, 5:37 p.m.
    Problem is the current battery is some no-name that doesn't really fit. That's why I wanted to know which battery goes in as per factory specification. Thanks
    28 May 2017, 12:49 p.m. 28 May 2017, 12:49 p.m.
    the ref SR726SW from Sony should work fine.
