IWC cal 853- plese help verify originality
  • skand
    • Offline
    • 13 posts
    Member since 12/05/2023
      skand
      • Offline
      • 13 posts
        This is my first post, I wanted to say hello and ask for help in verifying
        this watch. To me it looks ok, but I was confused by the large discrepancy of
        serial numbers in the mechanism and case number. I haven't come across a watch
        like this anywhere with an 18K version and a diameter of about 36.6mm. Could
        it be that they got an order from Sweden for commemorative watches, gifts to
        thank them for 25 years of service, and took an early made case from the
        warehouse and supplemented it with the movement ? This is just a theory, as
        the watch looks compact and the difference in numbers is very large. Thank you
        in advance for your help.
      • Mark Fleminger
        • Offline
        • 3202 posts
        Member since 07/07/2013
        • Offline
        • 3202 posts
        Just WOW!
        The condition of your watch is spectacular and a little bit unusual!
        It looks fine to me and I can give the following additional information.....
        The movement dates from 1963.
        The case was most probably produced and delivered around 1955.
        I have no explanation to such a large gap in production , which is usually two
        to three years apart.
      • skand
        • Offline
        • 13 posts
          skand
          • Offline
          • 13 posts
            Mark, thanks for the feedback. Earlier, before I got here I asked a question
            on the Omega Forum whether this watch is a franken and we also could not deal
            with this age difference of case and movement. I would have given up and
            treated the watch as utilitarian, but the fact that the watch as a whole looks
            like a unity does not give me peace of mind. Maybe someone else will have to
            add on this topic ?
          • Catherine
            • Hidden
            • 1009 posts
            Member since 13/09/2002
              Catherine
              • Hidden
              • 1009 posts
                Some of the gold manual sharkfin watches show a similar anomaly, albeit with
                cases produced in the very early '70's...they are also all in good order and
                have period correct original dials, just like your sample..showing a design in
                plum correlation to thier presentation.
              • skand
                • Offline
                • 13 posts
                  skand
                  • Offline
                  • 13 posts
                    Thanks Catherine for this post. Do you think this watch could have been so
                    assembled in the original? I have one original IWC with manual cal 89
                    movement, but here everything is fine in the movement correlation with the
                    dial case.
                  • Catherine
                    • Hidden
                    • 1009 posts
                      Catherine
                      • Hidden
                      • 1009 posts
                        Original equally clean dials in a style period to the watches presentation
                        would not be plentiful.
                      • skand
                        • Offline
                        • 13 posts
                          skand
                          • Offline
                          • 13 posts
                            My English skills are so poor that now, after the last post, I no longer
                            understand anything
                          • Catherine
                            • Hidden
                            • 1009 posts
                              Catherine
                              • Hidden
                              • 1009 posts
                                The watch presentation last date is post mid '60's.. so is the dial
                                style...whilst someone could have a case and mvmnt foriegn to each
                                iother...also having that specific dial is a stretch....unless youre a company
                                with your hands on whatever direction post late '60's took you.
                              • alicja1
                                • Offline
                                • 6 posts
                                Member since 15/05/2023
                                  alicja1
                                  • Offline
                                  • 6 posts
                                    Amazing style
                                  • HCP
                                    • Offline
                                    • 424 posts
                                    Member since 07/10/2002
                                      HCP
                                      • Offline
                                      • 424 posts
                                        Hi Skand,
                                        The watch looks perfectly legit to me, with my limited knowledge. I have a
                                        steel ref 500 with a cal 852 movement from 1952 that looks just the same. If
                                        you do not speak Swedish,the inscription is for General Motors Sweden,
                                        (Nordiska = Nordic, that is Sweden, Norway and Denmark) but you
                                        had probably figured that out already. May I ask for the hidden name? A
                                        relative?
                                        Henrik in Stockholm
                                      • davidoliver
                                        • Offline
                                        • 3 posts
                                        Member since 29/03/2023
                                          davidoliver
                                          • Offline
                                          • 3 posts
                                            IWC Caliber 853 is a well-known movement produced by the International Watch
                                            Company (IWC) in the mid-20th century. It is a hand-wound mechanical movement
                                            that has been used in various IWC watch models.
                                            To verify the originality of an IWC watch with Caliber 853, here are some
                                            steps you can take:
                                            1. Research the watch: Gather information about the specific model of the watch that contains the Caliber 853 movement. Look for details such as the case shape, dial design, hands, and any unique features or markings associated with that particular model.
                                            2. Examine the watch: Carefully inspect the watch for any signs of authenticity or inconsistencies. Look for matching serial numbers and reference numbers on the case, as well as any hallmarks or logos that indicate the watch is indeed an IWC.
                                            3. Seek professional expertise: If you have doubts about the watch's originality, it is advisable to consult with an expert or a reputable watchmaker who specializes in IWC watches. They will have the knowledge and experience to examine the watch thoroughly and provide an accurate assessment of its authenticity.
                                            4. Check the movement: The IWC Caliber 853 movement has specific characteristics that can help determine its authenticity. These may include the movement's finishing, engravings, and any unique features or markings associated with it. A trained expert can examine the movement and compare it to known authentic examples to verify its originality.
                                            5. Documentation and provenance: If you have any accompanying documentation, such as original papers, receipts, or service records, they can provide valuable information about the watch's history and authenticity. Verify the authenticity of these documents as well.
                                          • Lalanaini
                                            • Offline
                                            • 4 posts
                                            Member since 28/05/2023
                                              Lalanaini
                                              • Offline
                                              • 4 posts
                                                Agree with your viewpooint,
                                              • Mark Fleminger
                                                • Offline
                                                • 3202 posts
                                                • Offline
                                                • 3202 posts
                                                " Manual-Winding Movement: The CAL 853 is a manual-winding movement, meaning it requires regular winding by the wearer to keep it running. This traditional winding method adds a sense of connection and involvement with the timepiece."
                                                Correction
                                                Cal 853 is an automatic movement..
